Virtualizor updates gives VPS Providers grey hair and sleep deprevation
2»
  • mikhomikho AdministratorOG
    @seriesn said:
    Btw, thank you for the quick fix. Despite all the negative stuff, I do have to add that, Virtualizor support quality improved a lot vs the past.
    As I said in the original post, I like the product, only wish that some things were handled differently (read better).
    Thanked by (1)seriesn
    I meant the negative stuff about virtualizor in general ?.
    You and I are on the same boat with broken stuff ??
    Thanked by (1)mikho
  • edited January 2021
    @Neoon said:
    As LONG you dont push that forbidden button called RESTART or STOP inside that said Panel or the Provider reboots the node.
    You are fine, but if you do that, you are joining a round of russian roulette, you don't know what will hit you.
    Looks like I can't reinstall the KVM until the alleged bug is fixed.
    I say alleged because there's no recent bug report on Virtualizor forum.
    https://www.softaculous.com/board/index.php?#cid6
    It's time to ditch Virtualizor and make an open-source VM control software.
    HostBrr aff best VPS.
    We are impotent.
    sounds like 10,000 pushes
    up and down up ... up and down
    reminds me of ; someone already posted
    @yoursunny said: It's time to ditch Virtualizor and make an open-source VM control software.
    Proxmox community edition (what I use) or Cloudmin?
    Thanked by (3)ehab yoursunny Asim
  • love the Proxmox --- it is true love
    Thanked by (1)Asim
    @Freek said:
    @Freek said:
    @chirag said:
    Hi,
    Sir ok, we will not add any new features to the patches from now on.
    It will be purely bug fixes.
    Well that was easy.
    Again, all been said before over the years, it will not happen and if it does it will not last.
    2 weeks in your testing/experimental branch (which no one is stupid enough to run in production and you guys are as shit are not testing) before forced into stable? how about you just actually listen and stop imposing updates altogether, allow your paying customers to decide when it is stable and let them roll back when it is not.
    I appreciate there is a point when you need people on a minimum version, that is not 2 weeks, who do you think you are Archlinux?
    I was being sarcastic, I see I forgot the /s in my post ;)
    lol sorry you must have left the /s in your beta branch.
    Branches? How do you mean I can't push to master? I obviously just did! Do you know why Ci/CD just triggered a deployment? Yes I turned off the tests as the warnings were annoying. By the way why is our production down?
    ;) /s
    Thanked by (1): c1vhosting.
    LinuxFreek.com
    I used to always force-push to master, and I get complaints every week.
    Now I have a single develop branch that I can force-push, and the master or main branch that I don't force-push.
    My deployment is generally based on the develop branch after CI passes.
    We are impotent.
    We're derailing this thread, but... I would be one of the people complaining :) Wouldn't it be way more clear do keep your commits "atomic" (as the consultants tend to say) in your dev branch and instead squash+merge to master?
    @AnthonySmith calling cleanup in isle 3.
    @LES-Moderator (is that a space in the username?)
    Would like to keep this topic on subject as it is posted in ”Industry News”.
    —this message will self-destruct after a Moderator has read the message—
  • @yoursunny do the honours
    pimp push up
    @ehab said: Proxmox
    to a whole new level.
    edited February 2021
    @chirag said:
    Hi,
    ============== Patch 7 ==============
    1. [Task] Virtio will be default NIC Driver for Proxmox KVM since 3.0.5.7
    Is this considered a patch or new/changed feature?
    Should it be included in a patch release?
    According to your blog.
    Patch 6 was released on Jan 29th.
    Now patch 7 on Feb 2.
    Thanked by (2)Asim Freek
  • VirtualizorStream
    Thanked by (3)yoursunny Asim AlwaysSkint
  • AsimAsim OGServices Provider
    @Neoon said: VirtualizorStream
    and then comes Rockylizor lol
    Thanked by (1)Abdullah
    It's tough to believe their Proxmox support is fully broken. I'm sure they didn't test proxmox support before rolling out officially.
    I only discovered that after setting up one of the nodes.
    Windows VMs don't work, disk drivers are set incorrect, CPU topology does not set sockets & cores correct. backups are broken, the list goes on and on.
    Things need to be changed from proxmox manual..I'm stuck. :/
    This after the latest patch? Or earlier?
    All of those issues exist as I write now, I reported them in January, so they're slowly correcting those I think .
  • To be really honest, why bother running virtualizor on top of proxmox? Unless it is absolutely needed, I would simply migrate the instance and either go virtualizor or proxmox.
    Correct, that makes no sense. I'm already thinking of move to Proxmox only.
    It's open source, free & works great.
    Using Blesta, there is a nice Proxmox provisioning module, but it has not been updated for long & needs repairs.
    Thanked by (1)Asim
    ProxCP looks good
    Thanked by (2)Abdullah Asim
