@Neoon said:
aeza 1.46€ Sweden Promo
However I only paid 114RUB = 1.11€
Seems like they limited to 100Mbit/s finally. Did you get the VPS from the 5.42. range?
To expensive, I have only one VPS that cost 5€/m which is justified.
This cannot be justified, I am sorry.
I meant the IPv4 subnet range. They have new ones in Sweden so I would like to get again the promo with their new ones (already have one in 5.42 subnet)
The network looks like garbage tough.
Jitter and Packet loss wholesale.
I wanted to Ticket them, but when I forgor I can't because its a promo package.
You can contact them on Telegram, but don't expect anything with a promo deal. I've had issues in the past with their Amsterdam one but couldn't figure it out what was happening, so I just used a VPN instead. Well, 4 months with that one and now seems stable, altough there's some network packet loss some times
Uptime of the Sweden PROMO (it's 100%, I reinstalled the O.S recently)
Uptime of the Amsterdam PROMO
I mailed them, my email got ignored.
Besides that, when I look closely at the mtr.
I can see that their network is loaded beyond repair.
The gateway has a response time from 1 to 20ms, which correlates with the latency spikes I see.
Tbf, most gateways in the hosting industry (atleast as far as I've seen) have those spikes. You can use https://check-host.net and you'll see them in most of the cases.
You need to contact them on Telegram, they will ignore other contact methods.
EDIT: How did you calculate that? I've tried multiple traceroutes to 1.1.1.1 and all of them the gateway is below 1ms (also keep in mind my SWE-PROMO is very old, from one of the first batches, so it's not limited to 100Mbit/s and it's super fast, I've got a second one a month ago IIRC and it was slow as crap)
nah, if you see the gateway latency at 20ms, shits on fire yooooo
Yeah obviously if pinging inside, but if you ping the gateway outside the network it usually has spikes on some countries. Atleast for what I've seen.
I did install my beloved https://github.com/Ne00n/wg-mesh and wanted to use this as my swedish pop.
However, wg-mesh flagged 21 of the initially 33 connections as jitter.
We talking +20ms on each of these links, its def. their network, which is fucked.
If it would be a small issue, I might see like 2-4 links flagged.
This is a TCP ping to the SSH port. There's some jittering, but overall works perfectly fine (atleast on my instance)
Too high, way too high.
That's from my PC. That's normal ping to Sweden from Spain.
ruvps.net ("NVMe & "100Mbit/s") in Ukraine ($4.5 USD) (P.S. do not buy from them, they're scammers & will block your tickets, just want to show their shitty server)
# Yet-Another-Bench-Script #
# v2023-09-06 #
Sat Oct 7 09:52:08 PM UTC 2023
Uptime : 0 days, 0 hours, 3 minutes
Processor : QEMU Virtual CPU version 2.5+
CPU cores : 1 @ 2297.338 MHz
AES-NI : ❌ Disabled
VM-x/AMD-V : ❌ Disabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 29.5 GiB
Kernel : 6.1.0-9-amd64
VM Type : KVM
ISP : Kutumova Elena Vladimyrovna
ASN : AS51264 Kutumova Elena Vladimyrovna
Host : Kutumova Elena Vladimyrovna
Country : Ukraine
Read | 378.00 KB/s (94) | 6.05 MB/s (94)
Write | 399.00 KB/s (99) | 6.38 MB/s (99)
Total | 777.00 KB/s (193) | 12.44 MB/s (193)
Read | 11.78 MB/s (23) | 11.49 MB/s (11)
Write | 12.83 MB/s (25) | 12.85 MB/s (12)
Total | 24.62 MB/s (48) | 24.35 MB/s (23)
Clouvider | London, UK (10G) | 57.9 Mbits/sec | 79.7 Mbits/sec | 41.3 ms
Scaleway | Paris, FR (10G) | busy | 78.4 Mbits/sec | 37.7 ms
NovoServe | North Holland, NL (40G) | 65.5 Mbits/sec | 78.4 Mbits/sec | 33.9 ms
Uztelecom | Tashkent, UZ (10G) | 43.6 Mbits/sec | 74.7 Mbits/sec | 75.7 ms
Clouvider | NYC, NY, US (10G) | 33.9 Mbits/sec | 76.5 Mbits/sec | 112 ms
Clouvider | Dallas, TX, US (10G) | 7.89 Mbits/sec | 68.6 Mbits/sec | 270 ms
Clouvider | Los Angeles, CA, US (10G) | 18.3 Mbits/sec | 69.8 Mbits/sec | 179 ms
Test | Value
Single Core | 409
Multi Core | 406
Full Test | https://browser.geekbench.com/v6/cpu/2972596
YABS completed in 35 min 42 sec
2 x 2TB Solidigm P44 Pro SSDs (similar to SK Hynix Platinum P41) in ZFS mirror
2 x 20TB Seagate Exos X20 hard drives in ZFS mirror
Fractal Design Node 804 case
10Gbps internet connection via TRENDnet 10Gbps PCIe Ethernet card, Mikrotik CRS312-4C+8XG-RM switch, TP-Link ER8411 router, AdTran 822v ONT. IPv6 not enabled yet because apparently my router doesn't actually have an IPv6 firewall yet ¯\_(ツ)_/¯
Running Unraid which is based on Slackware
All CPU power saving settings are on to conserve power, which may affect the GB6 test result a little bit.
# v2023-09-06 #
Fri Oct 13 15:15:18 PDT 2023
Uptime : 36 days, 4 hours, 34 minutes
Processor : 13th Gen Intel(R) Core(TM) i5-13500
CPU cores : 20 @ 2500.000 MHz
AES-NI : ✔ Enabled
RAM : 62.4 GiB
Swap : 0.0 KiB
Disk : 60.3 GiB
Distro : Slackware 15.0 x86_64 (post 15.0 -current)
Kernel : 6.1.38-Unraid
VM Type :
ISP : Sonic Telecom LLC
ASN : AS46375 Sonic Telecom LLC
Host : Sonic.net, Inc.
Country : United States
tail: cannot open '2' for reading: No such file or directory
Read | 520.99 MB/s (130.2k) | 3.78 GB/s (59.2k)
Write | 522.36 MB/s (130.5k) | 3.80 GB/s (59.5k)
Total | 1.04 GB/s (260.8k) | 7.59 GB/s (118.7k)
Read | 5.23 GB/s (10.2k) | 5.81 GB/s (5.6k)
Write | 5.51 GB/s (10.7k) | 6.20 GB/s (6.0k)
Total | 10.75 GB/s (21.0k) | 12.01 GB/s (11.7k)
Clouvider | London, UK (10G) | busy | 1.59 Gbits/sec | 141 ms
Scaleway | Paris, FR (10G) | 2.62 Gbits/sec | busy | 143 ms
NovoServe | North Holland, NL (40G) | 1.20 Gbits/sec | 1.26 Gbits/sec | 146 ms
Uztelecom | Tashkent, UZ (10G) | 1.81 Gbits/sec | busy | 231 ms
Clouvider | NYC, NY, US (10G) | 2.64 Gbits/sec | 3.24 Gbits/sec | 72.4 ms
Clouvider | Dallas, TX, US (10G) | 945 Mbits/sec | 1.43 Gbits/sec | 154 ms
Clouvider | Los Angeles, CA, US (10G) | 3.51 Gbits/sec | 8.04 Gbits/sec | 12.2 ms
Test | Value
Single Core | 2485
Multi Core | 12662
Full Test | https://browser.geekbench.com/v6/cpu/3065449
YABS completed in 8 min 44 sec
1€ IONOS Frankfurt Equinix
@Neoon
Amadex • Hosting Forums • Virtmach • Wie ist meine IP-Adresse? • AS215325
what is dis
@Neoon dis is ionos server too
Our L2G NVMe 10Gbit plan in Spokane, WA
HostEurope 1.20€ VPS 80% off
I did select Europe for this one, got Strasbourg
HostEurope 1.20€ VPS 80% off SG
HostEurope 1.20€ VPS 80% off IN
Yabs after Speedypage upgrades to Ryzen 9 7900 and DDR5 ram.
v2023-09-06
Mon Sep 18 20:09:33 BST 2023
Uptime : 3 days, 11 hours, 38 minutes
Processor : AMD Ryzen 9 7900 12-Core Processor
CPU cores : 8 @ 3699.982 MHz
AES-NI : ✔ Enabled
RAM : 11.6 GiB
Swap : 5.8 GiB
Disk : 193.8 GiB
Distro : Ubuntu 22.04.3 LTS
Kernel : 6.4.16-060416-generic
VM Type : KVM
ISP : SpeedyPage Ltd
ASN : AS142594 SpeedyPage Ltd
Host : SPEEDYPAGE-LTD
Country : United Kingdom
Test | Value
Single Core | 2575
Multi Core | 10537
Full Test | https://browser.geekbench.com/v6/cpu/2658384`
Pretty nice considering the 6W TDP
Godaddy / Hosteurope Phoenix 1.20€
Racknerd New Year 2023
Sultan Muda - Amazon Store
hostEONS.com - Ryzen VDS - $8.99 - 2 vCore / 8 GB RAM / 100 GB NVME / 30TB / 10G Port - LES EXCL
https://dttech.net - Personal Site.
Xeroz.Tech - Mumbai, MH - India - EUR 1.3/month
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals | Cheap VPS Deals
nice.
10gbit without iperf3 Network Speed Tests is senseless.
Linode Chennai,
PREVIOUS CONFIGURATION: AMD Ryzen 9 5950X 16-Core Processor
Virmach after migration to LAX.
HXServers
A 1 CPU, 1 GB RAM, 50 Mbps Bandwidth (Netherlands) from hostvds
Got my hands on a Steam Deck finally, so naturally had to run a YABS. Got the 64 GB version and replaced the disk with a Corsair MP600 Mini
Website: thomassen.sh
Love these cheap builds
Hivelocity NYC
drServer's Intel Xeon E-2136 dedicated server
New home server:
c1vhosting €15/year - 2C/2G/900GB/500M
