@lapua said:
how much traffic does one yabs produce?
is 119 GB possible?
12:20 418.13 GB of 20 TB Used
12:23 537.45 GB of 20 TB Used
on 10G yes
Can confirm, definitely possible. And because I was curious, here's some back of the napkin math:
7 IPv4 locations + 7 IPv6 locations = 14 servers
2 tests (send and recv) per server * 14 servers = 28 tests
10 seconds per test * 28 tests = 280 seconds
280 seconds * 10 Gbit per second = 2800 gigabits
2800 gigabits / 8 bits per byte = 350GB of data
So the theoretical maximum amount of traffic you could use is 350GB if you are using machine with a 10Gbit link and have a "perfect" 10Gbit connection to every server over IPv4 and v6 (assuming every iperf server is also 10Gbit).
In reality, you're more likely to average ~1Gbit connections to all the servers even with a 10Gbit link. So I'd expect typical usage to be maybe 1/10th the theoretical max.
is 119 GB possible?
on 10G yes
was temporarily suspended for exhausting almost all of my 750G bandwidth within less than an hour after running a few times. thats how i know 🤣
is 119 GB possible?
on 10G yes
It's a wonder that there isn't an effort from providers to boycott YABS yet
is 119 GB possible?
on 10G yes
then you will see me shaming them like how yoursunny does.
is 119 GB possible?
on 10G yes
-r this option reduces the number of iperf locations (Online.net/Clouvider LON+NYC) to lessen bandwidth usage
oh! only error with r option!
curl -sL yabs.sh | bash -r
# Yet-Another-Bench-Script #
# v2022-08-20 #
Di 11. Okt 21:33:47 CEST 2022
bash: Zeile 28: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
Warning: locale 'C' not detected. Test outputs may not be parsed correctly.
bash: Zeile 84: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
bash: Zeile 85: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
bash: Zeile 88: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
bash: Zeile 92: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
bash: Zeile 93: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
Warning: Both IPv4 AND IPv6 connectivity were not detected. Check for DNS issues...
Uptime : 0 days, 23 hours, 46 minutes
Processor : AMD Ryzen Threadripper 3970X 32-Core Processor
CPU cores : 1 @ 3699.944 MHz
AES-NI : ✔ Enabled
RAM : 1,9 GiB
Swap : 0,0 KiB
bash: Zeile 234: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
Disk :
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-18-amd64
bash: Zeile 256: /dev/null: eingeschränkt: Die Ausgabe darf nicht umgeleitet werden.
You do not have write permission in this directory. Switch to an owned directory and re-run the script.
Exiting...
# v2022-08-20 #
AES-NI : ✔ Enabled
RAM : 1,9 GiB
Swap : 0,0 KiB
Disk :
Exiting...
use the command as mentioned in the github page. Best regds
on 10G yes
WOW!
Squats are the new Push-ups
freak!
Why not make -r the default, and pick servers based on location?
oh! only error with
r
option!Is this offer still available, i haven't been able to locate
RTFM
no longer available. it was part of their anniversary deal. sold out really quick.
Re-run of three latest machines now that GB5 is working.
Link to previous attempt.
GreenCloudVPS 9999 Birthday RO Bucharest $99 every 3 years
GreenCloudVPS 9999 Birthday IL Chicago $99 every 3 years
VirMach NVMe2G Phoenix, $0 every month, IPv6 via Route48 Las Vegas
HostBrr aff best VPS.
We are impotent.
Man, how were you able to get 3 of them?
MaxKVM ADX-2 Singapore ($13)
Email for £1/m (aff link)
My GreenCloud Chicago 2GB Ryzen VPS always gets null-routed during yabs. I'm surprised yoursunny could yabs it.
App DevTools | Convert.in.th | ConvertOnline.net | MP4 to MP3 | PDF to Pic
Virmach AMS with 2 x 1gbps LACP
BF2021 Special
12.95 knives / year
Inception Hosting Phoenix Black Friday 2021
2 GB RAM 2 CPU 50 GB NVMe
30 euros a year
I'm considering if I should renew this VPS. Everything has been great but the disk speed isn't as fast as NVMe.
Vultr Singapore, 2048 MB Intel High Frequency, $12/m
Vultr Amsterdam, 2048 MB AMD High Performance, $12/m.
(Not sure what happened here or why someone would choose these over the Intel ones, see YABS above).
AMD EPYC VDS from Server-Factory
GreenCloudVPS 9999 birthday special: 9 cores, 9 GB RAM, 99 GB SSD RAID-10, 9 TB monthly transfer, $99 every 3 months, sold out.
Green Daddy's 9th BIRTHDAY PARTY
Roughly $7.9/m ($95 - 1 year plan)
buyvm SLICE 1024 LU
impressive. not that much suckers in here with such a Single Core value.
Speedypage VPS - Singapore - Custom 20g ram
BuyVM Luxembourg Ryzen 5900X 1GB and Slab 256GB
IPv4 and IPv6 Non-premier account
Added IPv6
