Quick review: GreenCloud JP 10Gbps Storage-2 (SoftBank) – 4 vCPU / 6GB / 2TB HDD – $80/yr
Hi all,
Grabbed this one during the Black Friday restock hunt a few days ago and thought I'd share some numbers, since storage boxes in Japan don't show up that often.
Plan: JP10GbpsStorage-2 (Softbank), Tokyo
4 vCPU / 6GB RAM
60GB NVMe system disk + 2TB SATA HDD
4TB monthly transfer on a 10Gbps port
$80/year
It runs my self-hosted cloud storage and off-site backups, so mostly storage duty, not much compute.
YABS (trimmed):
Processor : Intel Xeon Processor (Cascadelake)
CPU cores : 4 @ 2494 MHz
RAM : 5.7 GiB
Disk : 2.0 TiB
Distro : Ubuntu 24.04.5 LTS
Geekbench 6: Single 997 / Multi 3011
https://browser.geekbench.com/v6/cpu/19519350
fio on the 60GB system disk (mixed R/W):
4k total 397 MB/s (97.0k IOPS)
1m total 2.21 GB/s
iperf3 IPv4 (send / recv):
Leaseweb Singapore 5.02 Gbits / 987 Mbits
Leaseweb NYC 4.13 Gbits / 1.74 Gbits
Clouvider LA 1.81 Gbits / busy
The 2TB HDD is not covered by YABS (it tests the system partition), so I ran fio on /data myself:
1M sequential mixed: ~310 MB/s read and write — better than I expected for a storage disk, looks RAID-backed
4k random mixed: ~100 IOPS — plain HDD territory, as expected. Fine for backups and file storage, don't run a database on it.
Two network quirks worth knowing if you consider this plan:
The IPv4 is a broadcast IP (xTom). Geolocation databases can't agree where it is — I've seen Germany, Netherlands and Japan depending on the database, and Disney+ is convinced it's in Germany. Most other services (Netflix, YouTube, ChatGPT) see it as JP, fraud score is clean (0). The IPv6 is native JP.
Return routes differ a lot between stacks: IPv4 goes via SoftBank (AS17676) and is decent towards Asia, IPv6 takes a long detour via GSL/Zayo except towards China Mobile. If you need good v6 routing to Asia, test before you rely on it.
Small note for fellow users in China: my first assigned IP got blocked by the GFW within a day. Support replaced it free of charge via ticket (took a few hours), after that it's $2 per change. Current IP has been fine since.
Verdict: for $80/yr, 2TB in Tokyo with a real 10G port is hard to beat for storage/backup duty. The CPU is old and the HDD is an HDD — as long as you buy it for the disk and not for compute, it's a good box.
Happy to run other tests if anyone is curious.
    Everybody flexes Debian, but Ubuntu precedes Debian in every OS selection menu in literally every VPS configuration panel in the universe. No exception.
    I run Ubuntu on machines with over 2 GB of RAM. In the past, Ubuntu’s packages were more up to date, which is why I chose it but nowadays I use containers everywhere, so I don’t really mind which OS is underneath.
