JSlinux, Linux, Freedos, windows 2000 in your browser - surprisingly functional.
InceptionHostingInceptionHosting Hosting ProviderOG
Check it out: https://bellard.org/jslinux/
I don't know what else to sat about it, it is what it is.
Thanked by (3)Amitz vpsgeek ITLabs
  • Windows 2000 was the last Windows version that I used on a regular basis...
    What a nice journey back in time.
    Thanked by (1)dahartigan
    And since then you have used Debian?
  • vpsgeekvpsgeek OG
    edited November 2019
    Which OS do you use for your laptop/desktop/workstation? Just curious :)
  • AmitzAmitz OG
    No, only for servers.
    I use OSX (macOS) on workstations since leaving Windows behind.
    Thanked by (1)vpsgeek
    vpsgeek said: Which OS do you use for your laptop/desktop/workstation? Just curious
    Windows 10 is my daily driver. I don't feel good about it, but I have been upgrading and migrating this puppy since windows XP!
  • Man you made my day!
    Now I can play solitaire on Windows2000 using my phone. Next step is install Lotus 1-2-3, grab some 5 1/4 floppy disks and connect to AOL.
    Thanked by (1)Amitz
    Wonder if the old notepad (or was it wordpad) help escape to system level privilege command shell works?
    will try tomorrow.
