i9-13900 Potassium Shared Hosting And KVM VPSes From MetalVPS!
Friendly greetings! 🌎🌍
Potassium, an i9-13900 MetalVPS Node in Finland, 🇫🇮 is available.
Do you want a shell account and shared web hosting for $3.00/month?
Do you want a KVM NAT VPS for $6.82/month?
Best wishes! 🌎🌍
Tom
Node Specs
CPU: 13th Gen Intel(R) Core(TM) i9-13900
Performance Cores: 8
Performance Threads: 16
Efficiency Cores: 16
Total Threads: 32
RAM: 64 GB DDR5 ECC
Disk: 2 x 1.92 TB NVMe SSD Datacenter Edition (Gen 4) RAID 0
Altroot Partitions: 2 x 100 GB EXT4 RAID 0
EXT4 Root Partition: 3.3 TB RAID 0
IPv4: 1 x IPv4/32
IPv6: 1 x IPv6/64
Network Speed: 1 Gbps
Bandwidth: Unlimited
Server OS: Debian 12.5
Webserver: Apache2
Single Slot Stackable Shell Account Specs
Fair use of Node Resources listed above
Disk: 50 GB
Bandwidth: 1 Tb @ 1 Gbps, shared, fair use
Single Slot Stackable KVM VPS Specs
CPU: Intel Core i9-13900
vCores: 1
RAM: 2 GB DDR5 ECC
Disk: 100 GB Datacenter NVMe SSD Gen 4 RAID 0
IPv4: 1 x IPv4 NAT, 1 forwarded ssh port + 20 additional forwarded ports
IPv6: 1 x IPv6/80
Bandwidth: 5 Tb @ 1 Gbps, shared, fair use
VPS OS: Debian 12.5
Stackable: Yes
VPSes made with: bashvm
Pricing
  • Stackable Shell Account Slot + Shared Hosting: US$3.00/month
  • Stackable KVM VPS Slot: US$6.82/month
  • Please make a lower price offer if you can't afford the regular price. Minimum price offers like $1.01 will be considered. Free offers will be considered too.
Payment
  • Payment will be requested after your account is set up.
  • Payment gateways available include Paypal and Zelle. Stripe also might work.
How To Sign Up
  • If you can, please say hello to @Not_Oles in #metalvps on Libera.chat.
  • Please email @Not_Oles at the address on his LES profile. Please include:
    • your real name and phone number;
    • your LES nic;
    • your use case for Potassium;
    • whether you want shell or VPS, and the number of stackable units you need;
    • your payment offer amount;
    • your ed25519 ssh public key;
    • link to your website;
    • link to your Github or other source repo; and
    • links to your other online profiles.
    • Please feel free to include additional information in your sign up request email.
Node Yabs
root@k ~ # curl -sL yabs.sh | bash
#                     v2024-04-22                    #
Wed May  1 08:06:17 PM UTC 2024
Uptime     : 0 days, 15 hours, 35 minutes
Processor  : 13th Gen Intel(R) Core(TM) i9-13900
CPU cores  : 32 @ 800.000 MHz
RAM        : 62.5 GiB
Swap       : 32.0 GiB
Disk       : 3.4 TiB
Kernel     : 6.1.0-20-amd64
VM Type    : NONE
ISP        : [Redacted] Online GmbH
ASN        : AS24940 [Redacted] Online GmbH
Host       : [Redacted] Online GmbH
Country    : Finland
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md5):
Read       | 1.59 GB/s   (398.7k) | 2.37 GB/s    (37.1k)
Write      | 1.59 GB/s   (399.8k) | 2.38 GB/s    (37.3k)
Total      | 3.19 GB/s   (798.6k) | 4.76 GB/s    (74.4k)
Read       | 3.04 GB/s     (5.9k) | 3.32 GB/s     (3.2k)
Write      | 3.20 GB/s     (6.2k) | 3.54 GB/s     (3.4k)
Total      | 6.25 GB/s    (12.2k) | 6.87 GB/s     (6.7k)
Clouvider       | London, UK (10G)          | 916 Mbits/sec   | 867 Mbits/sec   | 36.4 ms
Eranium         | Amsterdam, NL (100G)      | 927 Mbits/sec   | 924 Mbits/sec   | --
Telia           | Helsinki, FI (10G)        | busy            | busy            | 1.25 ms
Uztelecom       | Tashkent, UZ (10G)        | 881 Mbits/sec   | 600 Mbits/sec   | 67.5 ms
Leaseweb        | Singapore, SG (10G)       | busy            | 440 Mbits/sec   | 304 ms
Clouvider       | Los Angeles, CA, US (10G) | 807 Mbits/sec   | 278 Mbits/sec   | 151 ms
Leaseweb        | NYC, NY, US (10G)         | 867 Mbits/sec   | 628 Mbits/sec   | 92.3 ms
Edgoo           | Sao Paulo, BR (1G)        | 790 Mbits/sec   | 98.2 Mbits/sec  | 171 ms
Clouvider       | London, UK (10G)          | 906 Mbits/sec   | 847 Mbits/sec   | 36.5 ms
Eranium         | Amsterdam, NL (100G)      | busy            | busy            | --
Uztelecom       | Tashkent, UZ (10G)        | 890 Mbits/sec   | 646 Mbits/sec   | 67.4 ms
Leaseweb        | Singapore, SG (10G)       | 437 Mbits/sec   | 477 Mbits/sec   | 304 ms
Clouvider       | Los Angeles, CA, US (10G) | 806 Mbits/sec   | 292 Mbits/sec   | 151 ms
Leaseweb        | NYC, NY, US (10G)         | 855 Mbits/sec   | 653 Mbits/sec   | 92.0 ms
Edgoo           | Sao Paulo, BR (1G)        | 784 Mbits/sec   | 137 Mbits/sec   | 171 ms
Single Core     | 3195
Multi Core      | 18110
Full Test       | https://browser.geekbench.com/v6/cpu/5930582
YABS completed in 12 min 36 sec
root@k ~ #
Node Network-Speed
---------------------------- network-speed.xyz ----------------------------
      A simple script to test network performance using speedtest-cli
 Version            : v2024.04.14
 Global Speedtest   : wget -qO- network-speed.xyz | bash
 Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
 Basic System Info
 CPU Model          : 13th Gen Intel(R) Core(TM) i9-13900
 CPU Cores          : 32 @ 2799.341 MHz
 CPU Cache          : 36864 KB
 AES-NI             : ✔ Enabled
 VM-x/AMD-V         : ✔ Enabled
 Total Disk         : 3.4 TB (4.3 GB Used)
 Total RAM          : 62.5 GB (4.9 GB Used)
 Total Swap         : 32.0 GB (0 Used)
 System uptime      : 1 days, 20 hour 4 min
 Load average       : 0.06, 0.01, 0.00
 OS                 : Debian GNU/Linux 12
 Arch               : x86_64 (64 Bit)
 Virtualization     : NONE
 TCP Control        : cubic
 Basic Network Info
 Primary Network    : IPv6
 IPv6 Access        : ✔ Online
 IPv4 Access        : ✔ Online
 Location         Latency     Loss    DL Speed       UP Speed       Server
 ISP: [Redacted] Online
 Nearest          0.58 ms     0.0%    930.31 Mbps    928.47 Mbps    NextWing - Helsinki
 Kochi, IN        191.12 ms   0.0%    804.59 Mbps    471.59 Mbps    Asianet Broadband - Cochin
 Bangalore, IN    168.55 ms   0.0%    574.80 Mbps    548.05 Mbps    Bharti Airtel Ltd - Bangalore
 Chennai, IN      161.78 ms   N/A     648.91 Mbps    529.99 Mbps    Jio - Chennai
 Mumbai, IN       163.76 ms   0.0%    816.02 Mbps    414.86 Mbps    i3D.net - Mumbai
 Delhi, IN        159.56 ms   0.0%    616.71 Mbps    446.92 Mbps    Tata Play Fiber - New Delhi
 Seattle, US      165.11 ms   N/A     686.10 Mbps    550.39 Mbps    Comcast - Seattle, WA
 Los Angeles, US  156.39 ms   0.0%    904.97 Mbps    566.27 Mbps    ReliableSite Hosting - Los Angeles, CA
 Dallas, US       132.87 ms   0.0%    671.81 Mbps    671.63 Mbps    Hivelocity - Dallas, TX
 Miami, US        145.65 ms   N/A     886.32 Mbps    692.51 Mbps    Dish Wireless - Miami, FL
 New York, US     97.41 ms    0.0%    971.63 Mbps    862.10 Mbps    GSL Networks - New York, NY
 Toronto, CA      107.60 ms   0.0%    910.50 Mbps    805.23 Mbps    Rogers - Toronto, ON
 Mexico City, MX  155.61 ms   N/A     713.43 Mbps    589.19 Mbps    INFINITUM - Mexico City
 London, UK       39.15 ms    0.0%    940.06 Mbps    925.01 Mbps    VeloxServ Communications - London
 Amsterdam, NL    27.61 ms    0.0%    950.20 Mbps    936.85 Mbps    31173 Services AB - Amsterdam
 Paris, FR        34.49 ms    N/A     953.43 Mbps    941.40 Mbps    Axione - Paris
 Frankfurt, DE    20.58 ms    0.0%    929.53 Mbps    925.77 Mbps    Clouvider Ltd - Frankfurt am Main
 Warsaw, PL       18.29 ms    0.0%    931.86 Mbps    928.43 Mbps    Play - Warszawa
 Bucharest, RO    50.74 ms    0.0%    943.53 Mbps    941.25 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
 Moscow, RU       18.58 ms    0.0%    928.70 Mbps    928.39 Mbps    MegaFon - Moscow
 Jeddah, SA       117.47 ms   0.0%    936.23 Mbps    744.84 Mbps    Saudi Telecom Company
 Dubai, AE        152.62 ms   0.0%    908.12 Mbps    591.24 Mbps    du - Dubai
 Fujairah, AE     134.93 ms   0.0%    950.22 Mbps    642.72 Mbps    ETISALAT-UAE - Fujairah
 Istanbul, TR     59.82 ms    0.0%    942.30 Mbps    936.19 Mbps    Turkcell - Istanbul
 Tehran, IR       69.98 ms    0.0%    725.35 Mbps    937.46 Mbps    Asiatech - Tehran
 Tokyo, JP        293.70 ms   N/A     777.92 Mbps    296.62 Mbps    fdcservers.net - Tokyo
 Shanghai, CU-CN  269.84 ms   0.0%    650.79 Mbps    294.39 Mbps    China Unicom 5G - Shanghai
 Nanjing, CT-CN   254.03 ms   61.3%   565.15 Mbps    4.69 Mbps      China Telecom JiangSu 5G - Nanjing
 Hong Kong, CN    248.91 ms   N/A     658.60 Mbps    353.99 Mbps    STC - Hong Kong
 Singapore, SG    285.95 ms   0.0%    602.69 Mbps    301.45 Mbps    i3D.net - Singapore
 Jakarta, ID      FAILED - IP has been rate limited. Try again after 1 hour.
 Avg DL Speed       : 814.36 Mbps
 Avg UL Speed       : 656.93 Mbps
 Total DL Data      : 33.45 GB
 Total UL Data      : 25.87 GB
 Total Data         : 59.32 GB
 Duration           : 14 min 43 sec
 System Time        : 03/05/2024 - 00:50:32 UTC
 Total Script Runs  : 42325
 Result             : https://result.network-speed.xyz/r/1714696860_A6WT6J_GLOBAL.txt
root@k ~ #
Single Slot KVM VPS Yabs
vm1-tester@vm1-test-k:~$ curl -sL yabs.sh | bash
#                     v2024-04-22                    #
Wed May  1 19:13:25 UTC 2024
Uptime     : 0 days, 0 hours, 59 minutes
CPU cores  : 1 @ 1996.800 MHz
RAM        : 1.9 GiB
Swap       : 0.0 KiB
Disk       : 98.4 GiB
Country    : Finland
Read       | 881.10 MB/s (220.2k) | 4.61 GB/s    (72.1k)
Write      | 883.43 MB/s (220.8k) | 4.64 GB/s    (72.5k)
Total      | 1.76 GB/s   (441.1k) | 9.25 GB/s   (144.6k)
Read       | 4.57 GB/s     (8.9k) | 4.35 GB/s     (4.2k)
Write      | 4.81 GB/s     (9.4k) | 4.64 GB/s     (4.5k)
Total      | 9.38 GB/s    (18.3k) | 9.00 GB/s     (8.7k)
Clouvider       | London, UK (10G)          | 915 Mbits/sec   | 823 Mbits/sec   | 36.4 ms
Telia           | Helsinki, FI (10G)        | busy            | busy            | 1.63 ms
Uztelecom       | Tashkent, UZ (10G)        | 761 Mbits/sec   | 465 Mbits/sec   | 68.3 ms
Leaseweb        | Singapore, SG (10G)       | 348 Mbits/sec   | 446 Mbits/sec   | 304 ms
Clouvider       | Los Angeles, CA, US (10G) | busy            | 264 Mbits/sec   | 151 ms
Leaseweb        | NYC, NY, US (10G)         | 858 Mbits/sec   | 662 Mbits/sec   | 91.8 ms
Edgoo           | Sao Paulo, BR (1G)        | 775 Mbits/sec   | 148 Mbits/sec   | 172 ms
Clouvider       | London, UK (10G)          | 905 Mbits/sec   | 870 Mbits/sec   | 36.5 ms
Uztelecom       | Tashkent, UZ (10G)        | 875 Mbits/sec   | 615 Mbits/sec   | 67.8 ms
Leaseweb        | Singapore, SG (10G)       | 463 Mbits/sec   | 472 Mbits/sec   | 304 ms
Clouvider       | Los Angeles, CA, US (10G) | 742 Mbits/sec   | 294 Mbits/sec   | 151 ms
Leaseweb        | NYC, NY, US (10G)         | 825 Mbits/sec   | 630 Mbits/sec   | 92.2 ms
Edgoo           | Sao Paulo, BR (1G)        | 737 Mbits/sec   | 174 Mbits/sec   | 171 ms
Single Core     | 3211
Multi Core      | 3148
Full Test       | https://browser.geekbench.com/v6/cpu/5930199
YABS completed in 13 min 47 sec
Single Slot KVM Network-Speed
 Basic System Info
 CPU Cores          : 1 @ 1996.800 MHz
 CPU Cache          : 16384 KB
 AES-NI             : ✔ Enabled
 Total Disk         : 98.4 GB (1.3 GB Used)
 Total RAM          : 1.9 GB (281.5 MB Used)
 System uptime      : 1 days, 16 hour 42 min
 Load average       : 0.04, 0.01, 0.00
 Virtualization     : KVM
 TCP Control        :
 Basic Network Info
 Nearest          1.02 ms     0.0%    929.81 Mbps    927.65 Mbps    Valoo - Helsinki
 Kochi, IN        190.45 ms   0.0%    801.67 Mbps    462.47 Mbps    Asianet Broadband - Cochin
 Bangalore, IN    169.90 ms   0.0%    892.53 Mbps    532.14 Mbps    Bharti Airtel Ltd - Bangalore
 Chennai, IN      186.74 ms   N/A     534.86 Mbps    418.79 Mbps    Jio - Chennai
 Mumbai, IN       186.72 ms   0.0%    392.93 Mbps    326.79 Mbps    i3D.net - Mumbai
 Delhi, IN        164.31 ms   0.0%    654.72 Mbps    550.79 Mbps    Tata Play Fiber - New Delhi
 Seattle, US      184.72 ms   N/A     822.99 Mbps    488.28 Mbps    Comcast - Seattle, WA
 Los Angeles, US  154.75 ms   0.0%    878.53 Mbps    561.82 Mbps    ReliableSite Hosting - Los Angeles, CA
 Dallas, US       130.99 ms   0.0%    667.65 Mbps    666.94 Mbps    Hivelocity - Dallas, TX
 Miami, US        130.46 ms   N/A     762.99 Mbps    660.17 Mbps    Dish Wireless - Miami, FL
 New York, US     97.66 ms    0.0%    966.99 Mbps    846.58 Mbps    GSL Networks - New York, NY
 Toronto, CA      109.05 ms   0.0%    924.33 Mbps    797.22 Mbps    Rogers - Toronto, ON
 Mexico City, MX  154.46 ms   N/A     692.41 Mbps    550.19 Mbps    INFINITUM - Mexico City
 London, UK       39.54 ms    0.0%    938.81 Mbps    901.86 Mbps    VeloxServ Communications - London
 Amsterdam, NL    48.10 ms    0.0%    953.09 Mbps    902.17 Mbps    31173 Services AB - Amsterdam
 Paris, FR        33.87 ms    N/A     952.60 Mbps    921.43 Mbps    Axione - Paris
 Frankfurt, DE    21.02 ms    0.0%    929.29 Mbps    919.78 Mbps    Clouvider Ltd - Frankfurt am Main
 Warsaw, PL       19.14 ms    0.0%    932.33 Mbps    922.31 Mbps    Play - Warszawa
 Bucharest, RO    51.96 ms    0.0%    947.12 Mbps    895.42 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
 Moscow, RU       22.90 ms    0.0%    929.36 Mbps    920.42 Mbps    MegaFon - Moscow
 Jeddah, SA       101.23 ms   0.0%    940.67 Mbps    808.84 Mbps    Saudi Telecom Company
 Dubai, AE        156.71 ms   0.0%    916.69 Mbps    146.37 Mbps    du - Dubai
 Fujairah, AE     151.43 ms   0.0%    923.42 Mbps    571.08 Mbps    ETISALAT-UAE - Fujairah
 Istanbul, TR     59.42 ms    0.0%    942.64 Mbps    881.52 Mbps    Turkcell - Istanbul
 Tehran, IR       74.96 ms    0.0%    914.91 Mbps    839.15 Mbps    Asiatech - Tehran
 Tokyo, JP        308.33 ms   N/A     4.90 Mbps      296.10 Mbps    fdcservers.net - Tokyo
 Shanghai, CU-CN  276.32 ms   0.0%    765.38 Mbps    305.20 Mbps    China Unicom 5G - Shanghai
 Nanjing, CT-CN   FAILED
 Hong Kong, CN    265.28 ms   N/A     590.05 Mbps    355.30 Mbps    STC - Hong Kong
 Singapore, SG    285.48 ms   0.0%    419.01 Mbps    313.13 Mbps    i3D.net - Singapore
 Avg DL Speed       : 790.43 Mbps
 Avg UL Speed       : 644.48 Mbps
 Total DL Data      : 31.44 GB
 Total UL Data      : 23.82 GB
 Total Data         : 55.25 GB
 Duration           : 14 min 5 sec
 System Time        : 03/05/2024 - 16:14:19 UTC
 Total Script Runs  : 42374
 Result             : https://result.network-speed.xyz/r/1714752283_6Y5KAL_GLOBAL.txt
Warnings!!!
  • Forever Clueless™ administrator @Not_Oles has no "technical background" and only "limited technical skills. . . ." 😀 @Not_Oles frequently messes up! 😱
  • MetalVPS has no billing panel and no server control panel. It's traditional, command line terminal via ssh until @Not_Oles or you install whatever you want. 🆕
  • There are two preinstalled test KVM VPSes made with bashvm. You can get a juicy KVM NAT VPS into which you can ssh and install whatever Open Source software you want. :star:
  • Sometimes trusted MetalVPSians might or might not get sudo on Potassium, or KVM group membership, etc. 🙈🙉🙊
  • MetalVPS has no onboarding and no knowledge base. ♒︎
  • Account delivery might take awhile! 😴
  • Not for business use! Intended especially for computer learning and fun! 🤑
  • Occasional reboots are guaranteed, sometimes without advance notice! 🌺 VPSes can be set to restart automatically following reboot. :) If you have a special need for stability during a period of time, please let @Not_Oles know.
  • Please make your own redundant, offsite backups! It's easy to download or sync or clone your backup to a safe place. Please also check to make sure that you actually can restore from your backups! 🤦‍♂️
  • Please think of your MetalVPS account and all MetalVPS servers as ephemeral! Our Node might blow up! 💥 At any random second @Not_Oles or maybe you might reboot or even reinstall the Node! 😸 Or you or @Not_Oles might decide to cancel. 👹
  • Other MetalVPSians probably will see your name, your location, your account name, the processes you are running, and much other information. So, please do not put confidential information on the server. 🤔
Terms Of Service
  • Be awesome! Be kind, gentle, friendly, positive, and polite!
  • White Hat only!
  • Intended for education and fun!
  • Open source software only!
  • No Service Level Agreement (SLA)!
  • No refunds!
  • Redacted TOS also applies!
Help Wanted
  • Helping @Not_Oles learn more about The C Programming Language would be super great, and, if using MetalVPS, would be preferred over financial payment. Possible projects might include the C homework from the MIT free online Operating Systems class, adding UTF-8 to the Elvis editor, and messing with a 64 bit version of Bell Labs / Vita Nuova Inferno OS.
Support
  • LES PMs (personal messages) can be sent to @Not_Oles about items which need privacy.
  • Email to the address on @Not_Oles' profile also works.
  • You can use #metalvps at Libera.chat.
  • Of course, you also can post here in this thread.
More About MetalVPS
Frequently Asked Questions
Reviews
(万字测评) MetalVPS 2C 4G NAT 20端口+IPV6/128 月付$1.01USD 超快国际互联 优质备份鸡、下载鸡、大盘鸡🐔 超长详细测试+点评 低价大硬盘 强烈推荐!!!
(10,000 words review) MetalVPS 2C 4G NAT 20 ports + IPV6/128 monthly payment $1.01USD, ultra-fast international Internet, high-quality backup chicken, download chicken, large disk chicken 🐔 Super long and detailed test + review, low-priced large hard drive, highly recommended! ! !
What People Are Saying
  • About MetalVPS
". . . I sent a donation of $1.01, just because. Keep doing what you do."
"MetalVPS . . . seems to have endless servers."
"@Not_Oles . . . thank you for providing machine for me to help me finish all the tests."
"I really enjoyed MetalVPS . . . I hope more people can learn together using MetalVPS."
"非常感谢Not_Oles分享免费的MetalVPS为大家使用!" "Big thanks to Not_Oles for sharing his MetalVPS for people to use!"
". . . [V]ery cool that MetalVPS is still a thing :) Thanks for providing this to the community, tinkering with servers is fun and a learning experience!"
"The permanent free shell account of MetalVPS is very fun!" ("MetalVPS的永久免费shell账号挺好玩的")
"This is really really cool."
"I enjoyed the section of the OP dedicated to complementary comments, including helpful links so they can be verified."
"MetalVPS used to be a high end provider, but it's becoming a sorority now."
"fun stuff indeed, appreciating the comfortable computing experience!"
"Liking my darkstar"
"Nice trial and results! Very interesting :)"
Metalvps recommended on OGF 🙈
"It just crossed my mind that I've been using your server for over half a year! It's been an amazing experience! . . . Your services deserve much more attention. <3"
"Wow pretty nice ! Congrats excellent options thanks for being a part of the community"
"the terms seemed exceptionally fair"
"Kernel Linux 5.11 is now in much better shape for AMD <3"
"Yes, please. I’ll take that."
"it's really quite dedicated. not all dedicated are the same."
"MetalVPS-AX101 has a reasonable price"
"really need a testing ground badly now especially with dedicated core"
"the fastest VPS I ever used"
"I've been using this one from him. Highly recommend! His support is really amazing!"
"10/10 metalvps recommended"
"very powerful"
"premium stuff"
"Grab it while the hotel still has vacant rooms."
". . . very passionate and enthusiastic about everything. Not all businesses are made this way and it's very easy to see when you interact with them. You are giving the right impression with this industry and it's wonderful to see."
"I think MetalVPS is designed in between a dedicated and a regular VPS. Some use case cannot fill the capacity of a dedicated but need more CPU than a regular VPS, and it makes sense to use MetalVPS in such situation."
  • About Not_Oles
"@Not-Oles 在此非常感谢老爷爷👴的支持以及全力帮助 虽然有着非常多的时差,不过我们的交流仍然不会因此而产生隔阂,反而变得更好,我还是很喜欢这个人的,交流也没有障碍" "@Not-Oles I am very grateful to my grandfather👴 for his support and full help. Although there is a lot of time difference, our communication still does not create a barrier, but becomes better. I still like this person very much, and there is no barrier to communication."
"观察了挺长时间,没出啥问题" "I have been observing for a long time and there is no problem."
"这位老爷子看起来似乎很靠谱" "This old man seems to be very reliable"
". . . a certain... finesse."
"@Not_Oles . . . is doing all kinds of interesting work and sharing it with others"
"Hi Tom <3"
"Tom, you're the best :)"
"I found it interesting that Tom still treats his free vps members like humans (it's really admirable). . . ."
"@Not_Oles is really a funfull and helpful grandpa!!"
"especially thanks @Not_Oles , He pointed out my problems and told me the correct way to share. He is a good guy."
"I'm not in need for any free vps at the moment, but thanks for what you're doing. If I had this chance few years ago, I think my life would be different."
"I did want to thank @Not_Oles for always being so friendly. Makes me smile seeing how nice you are to everyone here."
"You are a great person."
"Possibly the most polite and enthusiastic personality in the entire LE* world with a genuine interest that runs so deep he even set up a business exclusively catering for LES. as a regular content writer for LES his articles frequently top the charts in terms of most viewed (according to google)"
"Really, you're the best person I've known on the internet."
"we've found that good, in-depth technical articles tend to drive user interaction and new sign-ups on the forum. @Not_Oles's Proxmox articles are evidence of this."
"It was a pleasure for me to collaborate with Tom, he really knows what he's doing :)"
"Thanks again to @Not_Oles for valiant testing."
"you've brought a smile on my face countless times "
"Good luck with your new project! :D Happy to have you around here!"
"I always love how you come up with new ideas :D Good luck, mate!
"May you continue to learn and inspire others."
"he is a great guy!"
"he is the sweetest guy in LES .."
"Everybody loves @Not_Oles! <3"
"resplendent as the Sonoran Sun"
"god bless not_oles ^^"
"every time I visit les and see that profile picture, it brightens up my day."
Crunchy
MetalVPS also offers accounts on Crunchy, a US 🇺🇸 MetalVPS server from @crunchbits! As of this writing, Crunchy is sold out, but might be restocked!
Thanks!
Thanks to @babywhale for bashvm!
Thanks to [Redacted] for awesome servers, awesome pricing, awesome Customer Service, and awesome reliability!
Tom a/k/a @Not_Oles gets a lot of help from the friendly MetalVPSians and from many other friends. Thanks to each and every one! <3
Thanks to @crunchbits for wonderful Crunchy! <3
Thanked by (3)wankel Janevski babywhale
